357 build
Old Mar 15, 2007 | 03:54 PM
335_GTA's Avatar
Car: 1991 GTA trans am
Engine: 305 tpi
357 build
Well I this is what I got for free
350 block bored .40 over completley redone (bearings,plugs...)
Redone crack
redone rods
new .40 pistons
mellings 480 lift camshaft
Will I be able to run a tpi set up on this if this is not a roller block?
I need some more info on this.
Old Mar 15, 2007 | 03:59 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Free!!!
Old Mar 15, 2007 | 08:15 PM
335_GTA's Avatar
Engine: 305 tpi
Yea a friend of mine ownes a machine shop and had it all laying around and he said if I wanted it take it. So I was like what the hell.
The cam,rings,pistons are all new in the box.
The crank,block,rods are all redone.
What should I do with it??
Will a tpi set up work??
Old Mar 15, 2007 | 08:54 PM
xgtharo86x's Avatar
Car: 86' Trans am
u should put it in your GTA..i dont know about the tpi setup you should go to the tpi section and ask
Old Mar 15, 2007 | 09:40 PM
335_GTA's Avatar
Engine: 305 tpi
This is the TPI section??
Well here is my prob. I dont want to run a carb, But will this motor work with a tpi setup?
Can I get some advice on this??
Old Mar 15, 2007 | 10:45 PM
Demon355's Avatar
Sure it will work with a TPI system. Why wouldn't it?
Old Mar 15, 2007 | 10:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I don't know why not. The only posible thing will be redrilling the four center bolts holes on the TPI intake manifold. This will be dependent on which heads you have. Not a big deal at all.
Old Mar 16, 2007 | 10:07 AM
335_GTA's Avatar
Engine: 305 tpi
I will be putting a set of ported 305 heads.
What all will I need to change ?
Injectors
prom
knock sensors
What else.
The heads are centerbolt heads, but what im worried about is the cam that came with it i dont know if it will work here look.
$89.95
287
230
230
.480
.480
107
111
2500-6000
22301
5- Hot Street Performance Code 5 cams have stong mid-range torque and top end power. They need a 9.5:1 or greater compression ratio, dual plane intake manifold with a 4BL carb, good dual point or electronic ignition and exhaust headers.
Does that mean that this cam wont work with tpi?? and only carb?
Old Mar 16, 2007 | 10:15 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You're right...it doesn't work with TPI (too big).
Old Mar 16, 2007 | 02:05 PM
335_GTA's Avatar
Engine: 305 tpi
So I would need a new cam ( prob just buy a whole valve train kit from comp)
Is that all?
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
