cheap power adders
Old Mar 19, 2007 | 07:06 PM
3rdgenlove's Avatar
cheap power adders
Hey im just looking for some cheap power adders so dont tell me about nos or superchargers. Im just looking for some cheap might get you 2-5 maybe 10 more hp i already have hooker headers and flowmaster mufflers on my 89 305tpi. Like does anybody use a msd ignition things on thos lines?
Old Mar 19, 2007 | 08:55 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
You have the exhaust.....what about the air intake?
Yes, plugs wires, cap, rotor, and coil all make a difference.
Dont forget about the gear in the rear of the car!!!
Old Mar 19, 2007 | 09:52 PM
3rdgenlove's Avatar
ok thanks i was planning on doing all of thos but the air intake where do you get that i cant find it at any stores
Old Mar 19, 2007 | 10:46 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Open air cleaner(K&N) would give you 5-10hp.
A good tune up would be the first place to start.(pretty hard to make the car faster if the plugs and wire haven't been changed in years)
Synthetic fluids help(engine oil, tranny and rear end)
You could port your plenum(do a search, lots of articles)
Check my sig for more ideas
Old Mar 19, 2007 | 10:47 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Don't mess with your air intake until you replace your upper crankshaft manifold.
In all seriousness Im not sure what car you have, wether it's TBI or TPI has a lot to do with it.
Old Mar 19, 2007 | 11:59 PM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
fyi gears dont have anything to do with power.
Old Mar 20, 2007 | 12:14 AM
3rdgenlove's Avatar
hey thanks guys all of this is awesome i do have a tpi and i do have k&ns i have seen cars at the local track that have just taken all of the air filter plastic off and just but a filter right on the throttle body can any one help me with this that also gets rid of the maf sencer??
Old Mar 20, 2007 | 01:12 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
No, but they affect how your car utilizes the torque band.
Old Mar 20, 2007 | 01:14 AM
bahsarie's Avatar
but the thread is about "power adder" not using it.
Old Mar 20, 2007 | 01:42 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
but I assume the point is for the original poster to go faster which proper gears can help with.
Old Mar 20, 2007 | 04:28 AM
F-Body Demon's Avatar
You might consider this for some power
1 port plenum ($25 DIY)
2 port runners ($25 DIY)
3 port base ($25 DIY)
4 port heads (this one is iffy, but hell 170 cfm to 250 cfm is huge) ($75 DIY)
4.1 If you have the money get bigger valves (not sure max size on 305) ($200 Have a machine shop fit to heads)
5 cam ($450 DIY including springs)
6 roller rockers ($300 DIY)
7 airfoil ($45 Ebay DIY)
8 TB Bypass (Dont buy the kit I mean seriously I used 2 hose clamps and about 1 foot of 5/8 hose so what $1.25 for 5 hp?)
Now you could do all this in one teardown to save time, give yourself about 8 days to work on it all. And how much do you seriously spend? A grand? sounds like a lot but you can build up the parts over a few months and then do it. But as for 2-5 hp....haha this isnt the combo for 2-5 hp. This is more the combo for 100 extra hp. So $10/hp. Kinda hard to beat actually not to mention you will be stomping the snot out of all the mustangs arround.
Old Mar 20, 2007 | 04:40 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
The oil in a K&N WILL destroy the heat wire in the MAF sensor.....!!!
Old Mar 20, 2007 | 12:20 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Re: cheap power adders
You take a car with a 2.73 gear and my car now with a 3.73.....lets see who gets to the from point A to point B 1st.
Most people want HP and forget about the gear in the rear end.
I only wanted to bring it up.
Old Mar 20, 2007 | 01:27 PM
3rdgenlove's Avatar
good point i was considering changing the ratio in my car as well
evilstuie
Apr 14, 2016 08:52 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
dutch930
Sep 11, 2015 06:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
