Crazy Looking TPI, check it out fellas!
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
http://cgi.ebay.com/ebaymotors/SBC-T...QQcmdZViewItem
I know it's an ebay ad, but this thing looks weird as hell. I wanted to see what you guys thoughts on it were. Good, bad, retarded... etc. I couldn't believe it when I saw it. Anyway, you get the idea.
Will
Will
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: Crazy Looking TPI, check it out fellas!
wow! Very weird for sure.
Looks rather big, but for some 2 TB's might be better the one.
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
It says so in the auction that he's gotta fab up a way to make them both open with one cable...
I bet that thing would be a monster with a big enough motor
Car: 92 z28
Engine: fast burn 385
Transmission: t56
does anyone else think this looks like a muffler on top of a tunnel ram type manifold? i know a lot of work went into it but i personally dot really like it. but i owuld be interested to see how it works on an engine. do before and after tests.
and btw, how do you control 2 IAC sensors also?
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
personally i think this thing looks pretty intimidating. i would think that you'd have to get a single throttle shaft machined to operate both t.b.s together. then have the tps mounted on the one on the left. as far as the iac goes; wouldn't one be able to control the idle, and the other one just be a dummy? (to fill the hole in the t.b.) i would love to see this up and running.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
anyone read " the injector bungs are epoxy'd " . What a hunk of junk !
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it looks to me like the plenum is big enough, looking at it, its maybe twice the size of a stock TPI & possibly close to 3 times the stock size. isn't the recommended plenum size half the displacement of the motor?
i agree, i would prefer the bungs to be welded in, but it would also depend on what type of epoxy they used, if they used the right type & cleaned everything right it will last with no problems.
the biggest thing i don't like about it is the angle of the injectors, they miss the back side of the valves by more than a little at that angle.
ok just to let you guys know, this thing sold for a measley $480.00 + shipping! now that's a sweet deal
Car: 92 Z28
Engine: Boosted LSX
Did you know that the TPI RUNNERS and glues in the flanges?
The worst thing about that intake is the injector angle. From the looks if it they are gonna be sprayin on the other side of the intake runner and not ON the back of the valve. Im gonna guess the plenum was done before the injectors and he then noticed they wouldnt fit. So did them like that.
deff.a piece of work.
Sanjay
Aug 12, 2015 03:41 PM
