TPS Adjustment steps question
Old Mar 24, 2007 | 09:11 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Ok I have read all the steps for adjusting the Throttle position sensor.
without pictures its hard to tell when they say hook up the volt meter to A and B terminals is that at the diagnostic plate or on A and B of the TPS?
and theres three jumper wires in between the TPS and the connector so if thats it then which of the three is A and B?
Can someone help me out?
Old Mar 25, 2007 | 05:03 PM
Dave87IROCZ's Avatar
Re: TPS Adjustment steps question
You need to jump the wires from the tps. I just probe from the back of the conector with my dmm. A is black B is dark blue.
Old Mar 25, 2007 | 05:39 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok but which terminals is A and B on the TPS there is 3 connectors on that sensor....
also the jump wires they are connected to the tps connector at the same time correct otherwise you wouldnt get any readings.... sorry i wish i had a picture of where the probes go and how the juper wires are set up
Old Mar 25, 2007 | 05:45 PM
camarosean's Avatar
Car: iroc-z
Engine: zz4
Transmission: tci 700r4
Axle/Gears: 4:10
step by step instructions with picture.you will need a multi meter or volt meter.if your car is more perfomane i would suggest .65volts closed throttle.not anymore above or ecm will set code. .54volts is stock.go to this link http://www.iroczone.com/techarttpsadj.html
Old Mar 25, 2007 | 05:47 PM
Bobby_80s's Avatar
Axle/Gears: no idea
great thanks a bunch thats what i needed to know
Old Mar 25, 2007 | 09:41 PM
camarosean's Avatar
Car: iroc-z
Engine: zz4
Axle/Gears: 4:10
no prob,message me if u need to anything about tpi,i specialize in tpi
Old Mar 25, 2007 | 09:49 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i may take u up on that. i bought this car to learn soem more on cars and i love the camaro/trans am look. im repalcing a lot on the engine. it hesitates in first gear. its an automatic. im not sure if its my distributor cap or my fuel pressure regulator or my fuel pump.
one thing at a time i guess
Old Mar 31, 2007 | 09:31 PM
Bobby_80s's Avatar
Axle/Gears: no idea
I printed out the IAC/TPS Adjustment instructions from this site. It doesnt say when to remove the paper clip from the A-B terminals in the diagnostic.
And how do you know if the paper clip is making full contact? when the engine light comes on, with just the ignition turned on?
do you remove the paper clip before or after turning the engine on to perform the IAC test?
And this sites intrustions does not mention the timing wire being disconnected but i have been told to do so while performing this procedure.
can someone enlighten me before i screw up my ecm?
thanks
mdtoren
Aug 23, 2015 12:52 PM
86IROC112
Aug 21, 2015 07:20 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
