Anyone running Crane Cam HR-284-2S-12-1G
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
After a lot of computer testing with DYNO SIM this looks to be the best cam for my planned buildup. Is anyone running this cam? I ask because Crane says it isn't computer compatible. But looking at the specs it should work with some computer tuning.
Thanks!
Brand: Crane Cams
Product Line: Crane PowerMax Camshafts
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,500-6,000 RPM
Intake Duration at 050 inch Lift: 222
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 222 int./230 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 292
Advertised Duration: 284 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.509 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.528 in.
Valve Lift with Factory Rocker Arm Ratio: 0.509 int./0.528 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: HR-284-2S-12 IG
Thanks!
Brand: Crane Cams
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Re: Anyone running Crane Cam HR-284-2S-12-1G
Don't think it'll be getting you 550hp. 480-510 ish. Just not enough duration.
Something around 236 degrees of .050" intake duration might get you there, if the heads are darn good.
Hmm....your wrong. I've made 600 hp on the dyno with close to the same cam on a Ford 400.
I've revised my thoughts, now I think about 450hp. Probably less through long runners. And I'm not trying to be a di*k either, honestly.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
IMHO that is a lazy cam. It has slow ramp rates. I think the Comp Cams XFI280 is a much better cam in that duration range if your heads can take the added lift.
It has more 8 degrees more duration at .050" and about the same or less seat to seat. Crane and Comp Cams measure the seat to seat differently so that is not apples to apples.
Last edited by 89Nighthawk; Mar 30, 2007 at 01:18 AM. Reason: Automerged Doublepost
Yeah, the HSR will help. Didn't see that in your post or sig (still don't). But, still not much cam for the power you're aiming for, and the lazy advertised to .050" ratio will not be computer friendly, until you dig into the prom a bit. Dual pattern typically is for exhaust flow problems. Do you have any restrictions (like possibly the exhuast port on those heads)?
What cam are you running now?
1988iroc350tpi
Aug 14, 2015 07:52 PM
