Miss at part throttle/backfiring
Old Mar 28, 2007 | 10:56 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Issue: I seem to get a miss and subsuquent backfires in my collectors at part throttle cruise. It is intermittant-comes and goes at will. I am going to check the following things, please tell me what else I can check.
-verify fuel pressure (recently replaced pump)
-ohm injectors hot & cold
-check plug wires for burns
-check plugs for fouling
-check dist cap/rotor (and obviously the wires for tight connections)
*ignition module/pickup coil/ignition coil new last summer
** stock 20 pound injectors (5.0 TPI setup on 355 block)
***Walbro 65gph fuel pump at stock fuel pressure on stock injectors
Thank You for reading..
Eric
Old Mar 28, 2007 | 11:34 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Miss at part throttle/backfiring
Start small, check plugs and wires as stated, and also check for exhaust leaks in that area. I have a crack by the muffler, and I get popping when coming down from a high rpm, I can only assume that yours might act that way if the leak is by the collector.
Good luck
Old Mar 30, 2007 | 07:32 AM
BOSS 357's Avatar
Engine: 357 SBC TPI
Thank you GJ, any more opinions on this?
Cleotiz
Jan 6, 2018 08:56 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
