Final assembly specs - what do you think?
Old Mar 30, 2007 | 09:33 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
The last of the parts are finally installed, and motor should be together this week. I hope to have it installed and running in two weeks.
Here are the specs:
I picked up a rebuilt 4 bolt main short block from Jasper bored .20 over with 4 way relief flat top pistons. It was ordered as a heavy duty pickup truck replacement short block and I got it for $400. The bottom end will do until I finish up my 383 short block.
ZZ4 heads, Comp cams extreme energy XR276HR, summit 1.6 self aligning roller rockers - comp cams dual springs.
Right now I have an accel super ram intake, and accel LTR's. Gasket matched the plenum to the runners as well as to the 58 mm BBK TB.
Accel 24# injectors.
I also converted from MAF to MAP.
The drive train is a t56 connected to a Moser rear with 4.11 gears.
Can I realistically expect mid 12's out of this setup?
I realize I am going to have to dig out all my prom burning stuff and tune the chip - it been a few years since I have done that!
Old Mar 30, 2007 | 11:07 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Final assembly specs - what do you think?
What heads are you using?
Old Mar 30, 2007 | 11:30 AM
LeeH's Avatar
Engine: 389
Like it sez - ZZ4 aluminum...
Old Mar 30, 2007 | 01:08 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Sounds like a good combo and I can't wait to hear what it runs.
Old Apr 16, 2007 | 08:40 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
when i was running that combo in my 355, i was making around 280 rwhp and some 300 rwtq with bad bearings and a distributor and coil that was shot. i never got to run it at the track though.....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
angel2794
Sep 8, 2015 06:22 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
