ECM jumper wire with engine on or off???
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
I keep reading the IAC adjustment steps and most say keep the diagnostic terminasl A and B grounded with a jumper wire with the ignition on.
tehn after all is said and done after turning on the engine and doing the min. air adjustment. it says turn off the car and remove the jumper wire or other way around.
I'm afriad this will ruin my ECM and I want a few people on here to tell me yes do not start engine with the terminals A and B connected or no its ok to have the engine running with the jumper wire in there to do the adjustment.
Please just someone tell me straight out yes or no if its ok and why.
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Re: ECM jumper wire with engine on or off???
NO..do not start the car with the jumper wire in the ports, this can damage the ECM
Axle/Gears: no idea
great finally thank you!!!!
now any idea why with the IAC and the timing wire near the passenger firewall disconnected why the car will instantly shut off after turning the engine on and starting it up?
theres these tech articles and i dont know how they dont ruin their cars or accomplish what they wright about because i follow the steps and cant get their results.
Car: red one
jump the A B turn key to on (do not start) wait about a min. for the ICA pintel to pull back, then unplug the ICA itself, turn off the key, pull the jumper and start the car, and set the min. idel air, after that put back together and then set your base timing. (might have to set min. air a fue times)
Axle/Gears: no idea
so dont disconnect the base timing wire untill i set my IAC? when u say set base timing you mean use the timing light with the first spark plug right?
Car: red one
YES, timing light one #1 plug wire with bypass wire disconected motor runing, it gets set at 6*BTDC.
Axle/Gears: no idea
ok thanks for the tip. i hope i dont have any trouble gettign the engine running. It wouldnt stay running with both IAC and base timing wire disconnected but hopefully will with only one disconnected.
Thanks for the advice
