89 IROC, TPI, at wot it boggs, then if I let off and slowly press the gas it is ok
Old Apr 4, 2007 | 05:56 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
I have a 89 TPI.5.0. when i really hit the pedal hard it boggs and does not want to give any more rpm's. If I let off the gas a little and gradually push it it does not bogg it runs ok. only when I am alredy going around 45 mph then if i hit the gas pedal hard it will do this. Do i need to adjust the trans cable that I hear guys talking about and If so how is that done.
Old Apr 4, 2007 | 08:51 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: 89 IROC, TPI, at wot it boggs, then if I let off and slowly press the gas it is o
Whats your fuel pressure at?
Old Apr 4, 2007 | 10:14 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
stock. I never checked it, how would i do that. this problem does not happen all the time, do you still think it is a fuel pressure problems if it happens twice a week.
Old Apr 5, 2007 | 10:13 AM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
is the fuel pressure the only cause for the car to bogg at WOT? or can there be something else. I just went through the painful experience of putting on a set of SLP runners and I would hate to take those off to replace the fuel pressure regulator. I was wondering if anyone else has experienced this, because it does not happen all the time and when it is colder out the car seems to run better. I have a custom stage 2 chip(agressive timming advance and idle is set higher due to the low voltage from the underdive pulley kit, SLP runners, emission stuff off, under drive pulley, not cat., ac delete kit, throttle body bypass kit,modified MAF,CAT. back exhaust, I am putting on edelbrock headers soon and a torque converter lockup switch asap. I have had rouble with the MAF before, I have gone through 3 of them,
I have replaced all the Maf relay's and the pigtail plug. Does anyone think it can be the MAF causing it since right now there is more air coming in the the exhaust is pushing out? I am open to any ideas and need help, My wife currently beat me with our minivan because of this problem and I am still recouping from this scar that is from losing to a minivan. So please Help, For the sake of all 3rd gen's out there that I represent. I need this fixed to regain my manhood and respect that we all deserve. Your 3rdgen brother, Jason
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
NBrehm
Aug 5, 2015 07:57 PM
