LT1 cam in a 305. will I need the LT1 timming chain set?
Old Apr 5, 2007 | 11:34 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
Do I have to buy anything besides grinding down the pin on the Lt1 camshaft to fit in my 89 TPI 5.0. will I have to buy a LT1 timming chain set or a 89 timming chain set. should I go with 1.5 or 1.6 rollers, I have stock heads.
Old Apr 6, 2007 | 12:22 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: LT1 cam in a 305. will I need the LT1 timming chain set?
Just cut off the tip of the dowel pin in the LT1 camshaft to the same size as the camshaft in your car now. Sorry I dont remember the exact specs, but perhaps a search can find them for you. Use a timing chain set for an '89 engine.
For stock heads, stick with 1.5 rockers with the LT1 camshaft. Its higher lift with 1.5 rockers will make it dangerously close to coil bind and valve guide interference with 1.6 rockers. Its also a very good idea to change your valve springs at the same time. If they're stock, the ones in your car are almost 20 years old and definitely worn out.
Old Apr 6, 2007 | 03:13 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I ran an LT1 cam in my 305 with 1.6 rockers...I also added some Z28 springs....ran fine! yeah just grind the pin down to the same size as your stocker...and run a double roller if you want..I did!
Old Apr 6, 2007 | 10:47 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Would you have to tune an SD car to run an LT1 cam?
Or would it be ok without a tune
Old Apr 8, 2007 | 02:38 AM
Kevin91Z's Avatar
It should run just fine with the stock chip. Putting in an LT1 cam with 1.5 rockers is almost identical as putting 1.6 rockers on a stock TPI camshaft. The durations are the same but the LT1 cam has more lift.
Old Apr 9, 2007 | 04:18 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
will it make the same amount of horsepower or close? when you say identical, would it be smarter to just change the rocker then going through all the trouble of a cam swap? I just purchased a LT1 cam for my 305, so if I could save the trouble of a cam swap and just do rockers I would rather do that. What would you do? And do you know what h.p gain I should expect from a LT1
Old Apr 9, 2007 | 06:41 PM
Kevin? doesnt it depend on what Lt1 cam was gotten? cause the one I had was from a 95-96 camaro and the duration/lift was no where near the 88-89 camaro specs....atleast according to the tech data. the one I had with 1.6 rockers was 203/210 477/480 and I did change my springs to go with it.
Old Apr 9, 2007 | 11:35 PM
Kevin91Z's Avatar
I really dont know which would be better, as I havent done either. Perhaps someone who has can chime in here. Either way, I would suggest upgrading the valve springs at the same time, as stock springs in a thirdgen are very old and worn out in this day and age.
Old Apr 9, 2007 | 11:55 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I`m running L-T4 production cam with 1.6 rockers giving me max lift .476/.480dur.@.050 203/210(pace performance part #12551142)I`m running the single roller chain that came on my crate engine.Cost about $100.00 new (cam).The LT-1 is dur.201/208 lift.447/459 with stock rockers i believe.(part #12551705)The prices on the web site have got to be wrong cause mine wasnt that much.
Old Apr 10, 2007 | 10:53 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
I put a LT1 cam in one of my '91's.
Put in some new lifters (had too) and new timing chain.
Did not change the valve springs.
Motor has Over 160k on it.
So far, after 3k+ miles no trouble!
(so far that is with fingers crossed!!)
Old Apr 13, 2007 | 10:40 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
.....why not change your valve seals while your in there too.....???? Just another thought.
I changed mine for sure!
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
TheExaminer
Aug 19, 2015 10:07 PM
