tpichips.com ?
Old Apr 6, 2007 | 03:08 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
tpichips.com ?
im going to build a biggass motor right away,, and plan on sticking with efi
do these chips work good,, i know BURN YOUR OWN CHIPS!!!!
but if all i ahve is a factory 305 chip,, and nothing to tune off,, how will i get the motor started!!!
motor will be a 400 sbc, with a fairly mild tappet cam, and probably stock heads for the time being,, somewhere in the 350 horse power 400 plus ft pounds,,, intake will be HSR or a custom sheetmetal one copying the one from tpis/ lt1 intake style
are these chips good enough? or is there a way i can get into chip burning without grenading my motor while trying to break it in? i dont feel like having a horrible A/F ratio and stupid timing on my beutiful pistons!!!
Old Apr 6, 2007 | 04:27 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: tpichips.com ?
some people have had good luck with after market chips, but most have gotten better results by making their own.
this question would probably be better in DYI-PROM.
is your car still running? if so, now is the time to start to learn how to burn your own.
depending on what you go with & if you already have a laptop & go the cheap way, about $100.00 will get you the stuff to get started. if you go hog wild, AutoProm, bin switcher & remote switch, wide band O2, your looking at around $700.00 or so.
to burn your own chip, a stock chip for a 350 would be better to start with, from there you make a few changes for engine & injector size. it probably wouldn't be a bad ideal to pull some timing during break in to be safe.
Old Apr 6, 2007 | 08:13 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: tpichips.com ?
I used him for the chip in my new engine.Its only temporary because i want to burn my own eventually.I just gave him a try because i was ready to drive my car after a year of saveing and building and he was affordable.I am happy with his work after 4500 miles and it appears he did a good job doing the things i asked for.If you have the extra money though I would go with Ed Wright fast chips.Also used him before and from what i understand he is one of the best if not the best,although twice as expensive.But as was stated you would get better results from doing your own.
Old Apr 6, 2007 | 09:08 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: tpichips.com ?
Jamy at LS Racing Chips gave me an excellent tune (mail order..told him my combo, he nailed it on the 2nd try; that's WAY ahead of me learning to 'burn chips', although I will be 'rolling my own' chips soon!). Give him a call (330) 575-4162, tell him Bill sent you!.....then learn to tune on your own.
3rd Gens rock.. you can always build for power, but LS1's just don't have the "mean" look.
Bill
white_ghost
Oct 22, 2012 11:49 PM
Tuned Performance
Dec 2, 2011 04:44 AM
PeterFeix
Apr 5, 2011 09:52 PM
Irocw89
Jul 29, 2010 05:34 PM
kozman
Apr 11, 2009 04:36 PM
