fuel pressure gauge opinions
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
I have been looking around for a fuel pressure gauge kit. I want to put it inside the car, probably on the pillar. I know its not a complicated install but still could use some ideas. Also I don't feel like buying all the components seperatly. Anyone know if there are any kits available? Its for a 350 TPI with AFPR. Thanks guys.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: fuel pressure gauge opinions
I got a Nordskog digital gauge. I had to plum the sender into the fuel rail. Really a simple install. It's clean. The sender is under the plenum so it's not seen.
Car: 92 GTA/ 00 TA
Engine: 383/350
Don't remember if it was ~60 or ~100 bucks. It's been in for a couple of years. It's accurate to within 1 pound vs my mechanical.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I got mine from Autometer. I'm using the Sport Comp 2 electric and it comes with pretty much everything. I added a 90 degree swivel fitting at the fuel rail and a 12" braided line to get the sending unit off the engine. The gauge kit was $195. Stewart Warner makes one as well but I don't know how complete it is.
Car: 89 Camaro RS
Engine: 350 TPI L98
Cool. Thanks for the replies guys. If anyone else has opinions, I would be glad top hear them.
I bought a cyberdyne since I wanted digital and it was red led and cheap and had recall. Below 30 psi it is +-5 psi, above that it is +-2 psi so Im not very happy with it and I have found nearly all of these cyberdyne models are that way.
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
