all of the injectors on the passenger side don't work all of a sudden?
Old Apr 12, 2007 | 10:20 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
My car runs like a piece of cr_P. All of the injectors seemed to of went out at the same time. I recently put on a new IAC,TPS and SLP runners. any ideas of what it is and how to fix it. there is no way all four can go out at the same time. I pulled off top clip part to check it when it was running at it confimed that all of the ones on the pass side are not working. I heard someone say somethng about a fuse in the computer fot TPI's that regulate all four on each side with a different fuse for each four injectors. if that is the case how do I fix that if the fuse is in the computer?
Old Apr 12, 2007 | 10:26 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: all of the injectors on the passenger side don't work all of a sudden?
Its not in the computer.
If any injectors fire, the driver in the ECM is working. You must find the supply fuse for each side and replace the blown one.
IDK the location but someone will chime in if you can't find it.
Old Apr 12, 2007 | 10:46 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
does any one know were the supply fuse for each side of the injectors are . I don't think they are the ones in the fuse box. those are fine. are there some anywhere else?
Old Apr 13, 2007 | 01:26 AM
84350twinturbo's Avatar
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
they are 10 amp fuses in the fuse panel they are marked injector 1 and 2
Old Apr 15, 2007 | 08:55 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
those fuses are ok. is there a fusable link or some other fuse for the injectors. does anyone know what to set a ohm meter at and what #'s am I looking for if I am suppose to check the injector wires?
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
