idle surge
Old Apr 15, 2007 | 08:52 PM
snapping turtle's Avatar
idle surge
I have a 87 tpi the car surges at idle on start up then stalls . If i hold the gas pedal down a little to keep the rpm up it will idle on its own after about 2 minutes of holding the gas pedal . The idle rpm will be where ever the rpm was when I held the gas pedal to keep it from stalling . I checked for vaccum leaks , set tps , iac , grounds . Other than that the cars runs great once it will idle on its own . If I shut the car off and start it right back up , it will idle fine . If I shut the car off and start it up ten minutes later it wont idle on its own . WTF!!!!
Old Apr 16, 2007 | 04:08 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: idle surge
check for vaccum leaks
junior419
Apr 7, 2025 11:35 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
