Code 54 after I replaced fuel pump relay
Old Apr 15, 2007 | 08:54 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
Am I on my way to replace another fuel pump like in the last car? I searched some and did not see any other options after the relay. I find it strange that it will not energize when the key is turned but then the pump runs fine the rest of the time once it is started. Would an alarm have any effect on the fuel pump?
Old Apr 17, 2007 | 07:20 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: Code 54 after I replaced fuel pump relay
the reason it runs once started is the oil pressure switch sees the 4lbs and closes,a direcxt power feed.do you having long crank starting problems?
Old Apr 18, 2007 | 10:26 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
yeah, I have had many times where it cranks for a long time and then does not start strong. The last couple days however it has been starting right up and not throwing the code. It seems to come and go. Maybe the pump is dying slowly.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
