tpi 305 to a 350
Old Apr 15, 2007 | 10:33 PM
84350twinturbo's Avatar
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
tpi 305 to a 350
i have a tpi set up from a 87 camaro i bought on ebay it is on its way i want to know if the tpi intake manifold will still fit the 350 or if there is some modification i have to do to it
thanks
Old Apr 17, 2007 | 08:55 AM
Casem1's Avatar
Car: 1999 Corvette
Engine: 460 HP LS1
Transmission: MN6
Axle/Gears: 4.10
Re: tpi 305 to a 350
First: Use punctuation. You look like a 2 year old got his hands on a keyboard.
Second: Tell us what heads you are using, as that is the only issue.
The only difference between a 350 and 305 is bore size, there heads are interchangeable. However, the bolt pattern and port location of some heads are different.
Old Apr 17, 2007 | 10:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It'll fit fine as long as they're late style heads on your 350.
Old Apr 17, 2007 | 10:53 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
..... there heads .....
You should speak .
Old Apr 17, 2007 | 05:09 PM
Casem1's Avatar
Car: 1999 Corvette
Engine: 460 HP LS1
Transmission: MN6
Axle/Gears: 4.10
Thanks, but I didn't say anything about spelling...
Old Apr 17, 2007 | 08:29 PM
canadian250's Avatar
Car: 1985 WS6 T/A
Engine: LB9 305 TPI
Axle/Gears: 9bolt 3:27
Good comeback!!!!
Old Apr 17, 2007 | 09:04 PM
Transmission: th400
im using brand new heads that are stock style ohh and by the way i would have used punctuation but i was to busy entertaining your mom. please next time answer the question or dont chime in ok i dont need the crap from the dee dee dee club ok. thanks again
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
