need help choosing intake for 58mm TB
Old Apr 16, 2007 | 12:10 AM
mi11ertyme's Avatar
Hey everybody. I have a question about what cold air intake to use for an aftermarket 58mm throttle body on an 85 Trans Am TPI setup. It actually has an accel super ram with BBK 58mm throttle body. Can anyone recommend a cold air intake besides the one from SLP? Or where they found parts to fabricate one? Thanks.
Old Apr 16, 2007 | 12:50 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Re: need help choosing intake for 58mm TB
I have the stock throttle body and am using the SLP intake.
If you want to make one yourself, you can bend one out of some exhaust pipe and slap an air filter on the end.
Old Apr 16, 2007 | 11:14 AM
mi11ertyme's Avatar
I was able to find some information on how to fab one up searching past forums. It looks like a very clean and fairly easy set up to make for about half the cost and probably works better than the SLP kit. Here is the link: https://www.thirdgen.org/forums/tpi/...completed.html
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
