slight sputter between 35 and 45mph
Old Apr 16, 2007 | 04:01 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I need help my car has a slight miss between 35 and 45 and really bad at 40 and no matter what gear its in or what rpm it is at i thought it was the tps so i replaced it and set the voltage at .56 no codes come up on the scanner and it seems to be worse the hotter it is outside but it doesnt matter how hot the coolant temp is please help its really pissing me off...thanx
Old Apr 17, 2007 | 03:47 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
Re: slight sputter between 35 and 45mph
help please
Old Apr 18, 2007 | 11:34 AM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
This doesn't sound normal for a miss; a miss is usually dependent on engine RPM and/or load. Are you sure you aren't experiencing some odd phenomena with the lockup torque convertor? the PCM commands lockup at this speed, and will apply lockup in 3rd and 4th gear, but not 2nd or 1st. You can just disconnect the connector for the convertor clutch from the trans and drive it; it wont set an error code and you can rule it out for sure this way.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
