FPR vacuum line
Old Apr 20, 2007 | 07:44 AM
pr1689's Avatar
Car: 86 Iroc Z28
Engine: 350 5.7L (rebuilding now)
Transmission: 700R4 shift kit
Axle/Gears: 3.73, 9-Bolt, stock posi
FPR vacuum line
I disassembled the engine about a month and a half ago and am now reinstalling it in the car. I am in the process of hooking the tpi back up and have forgotten where the vacuum line to the fuel pressure regulator hooks up to. Doesn't it hook up to the passenger side of the throttle body plenum? Also, since the egr isn't usable with the 113 heads I have, do I really need to hook up all the vacuum lines, etc to the egr pump, etc?
Any help would be greatly appreciated.
Thanks,
Pat
Old Apr 20, 2007 | 01:16 PM
pr1689's Avatar
Car: 86 Iroc Z28
Re: FPR vacuum line
bump... Anyone have any ideas? I've been looking at the vacuum diagrams and that it what it appears to be but I can't tell for sure.
Thanks,
Pat
Old Apr 20, 2007 | 02:18 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: FPR vacuum line
the fpr vaccum hose goes to the small vaccum port on the rear of the upper pleneum pass side.
I have never used the 113 heads but I would think you would use a block off plate for the egr valve
Old Apr 20, 2007 | 03:22 PM
pr1689's Avatar
Car: 86 Iroc Z28
Re: FPR vacuum line
Thank you Jamon8. I appreciate your reply and the confirmation of where I thought it was! Thank you for replying!!!!
Yes, I am using the egr block off plate but I didn't know if I would be throwing any codes without hooking up all those vacuum lines.
Thanks again!
Pat
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
