Will the Computer Pull Timing?
Old Apr 25, 2007 | 05:51 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Is 8 degrees advances base timing enough to make the computer pull timing at upper rpms, or is that a good point for TPI? From what I have read everyone seems to like 8-10. Thanks guys.
Old Apr 26, 2007 | 06:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Will the Computer Pull Timing?
8 BTDC is stock for mine. So that's where I put it. If for some reason something's not right, the ECM will pull back timing.
Old Apr 26, 2007 | 07:58 AM
Engine: LB9, LB9
Yeah mine is 6 stock, so I figured instead of putting it there I would go to 8 because I run premium in it anyway. I just dont want to slow the car down.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Thirim
Aug 9, 2015 06:19 PM
