305 Heads on 350
Old Apr 25, 2007 | 10:07 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
305 Heads on 350
I was wondering if there was any significant gains or losses with putting 305 heads on a 350. Did a search, and couldn't find much. Would like to here what you guys have to say.
Old Apr 26, 2007 | 12:08 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: 305 Heads on 350
Your compression will be raised. This can give you a little more performance but the 305 heads sport smaller valves and definetly should be ported to achieve max performance. Extensively ported 305 heads are a common performance mod on here.
Old Apr 26, 2007 | 03:35 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I am currently running 58cc 081's on my L98 roller.
I can say for sure, it has more power than it did before
I started the rebuild. Compression is raised a tad, but not
signifigant. I havent noticed any power-loss due to the
smaller head.. It seems a tad more peppy.
Depending on head choice, It might not be desirable
to machine/port them. 416's & the 081's seem to be
the most popular to mod & best flowing head of the $.
But, there are better flowing heads out there.
I successfully passed emissions with a 280 cam and
305 081 heads on a 350 with a stock tune in a L98 car.
So, the ECM likes it.. Though it is a tad lean.
Good luck
Old Apr 26, 2007 | 11:53 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
put in some 1.94 valves and have the seats redone and the chamber hoged out
Old Apr 26, 2007 | 08:37 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
Something you might like to know: take the 350 head gasket and lay it on the 305 head, and look at the head gasket compression ring and how close it is to the water passage in the head itself. What I am saying is that if the motor overheats you run a good chance of haveing to change the head gaskets.
good luck
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
