8.7 compression ratio
Old Apr 29, 2007 | 10:46 PM
footjoy's Avatar
Can TPI motor be built with 8.7:1 compression ratio to have really good streetable power.
I have a chance to buy a GM shortblock but it only has 8.7 cr with my vortec heads. I WOULD LIKE TO GET 325hp TO THE REAR WHEELS oops caplock.
fj
Old Apr 29, 2007 | 10:54 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: 8.7 compression ratio
Mill the heads and bring the compression up.
Old Apr 29, 2007 | 11:01 PM
footjoy's Avatar
how much can you mill vortec heads
Old Apr 29, 2007 | 11:06 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You can also use a thinner head gasket. GM makes a good one that is only .028" thick.
Old Apr 30, 2007 | 01:32 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
yah you are definitely going to want more compression, the easiest thing to do is to get the heads milled, and also use a thin gasket..... to see the biggest differece you need to change the pistons
Old Apr 30, 2007 | 02:00 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
i wouldn't mill the heads unless you had too. if you mill them now and a year or two down the road overheat and slighly warp the head surface the vortecs are ruined. also with the intake design you will also have to mill the intake side of the head. and some will say you can angle mill them and not do the intake but you gotta remember a vortec has that different bolt pattern and it will matter. been there and done that.
Old Apr 30, 2007 | 03:18 PM
bigchief's Avatar
i agree with this guy ^^
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
