305 HELP
Old Apr 30, 2007 | 01:34 PM
pattycakes's Avatar
305 HELP
'88 305 LB9 TPI- any suggestions on some simple things to get for most power/buck?
Old Apr 30, 2007 | 02:34 PM
chevylover5's Avatar
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
Re: 305 HELP
1. welcome to the board
2. try using the search button iv read about 10 threads like this one
3. try posting in the right section
Old Apr 30, 2007 | 03:00 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Re: 305 HELP
Moving to TPI where I believe you will get a LOT more suggestions.
Also, as chevylover5 says, a search will yield a TON of advice much quicker.
Old Apr 30, 2007 | 09:45 PM
pattycakes's Avatar
Re: 305 HELP
hah sorry guys - appreciate the guidance though
Old May 2, 2007 | 07:04 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: 305 HELP
some tips are in my sig. I hope it helps you.
Old May 2, 2007 | 07:07 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: 305 HELP
What timing gear set are you using that is compatible with the fuel injection system? I was wanting to get a gear set but haven't yet cause they all seemed to say there were not useable with computer controlled cars.
my bad don't reply to this I'm stupid. You have the part number right in your sig, lmao!
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
