any thoughts on this set up?
Old May 6, 2007 | 02:27 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
L98 350 Bored .30 over
Edelbrock Aluminum Vortech Heads
SDPC Vortech TPI aluminum Intake
SLP Intake runners Port matched to plenum and intake
Full Roller valve train with the following:
TPIS ZZ-9 Roller Cam Gross lift with 1.6 rocker is .515/.554 112deg lobe separation
Crane Gold Race Narrow Body 1.6 roller rockers
Manley hardened push rods ( w/guide plates ) OEM GM Roller lifters
24# GM injectors, flow tested and matched
Cloyes true roller double roller timming Chain
SLP 1 3/4 ceramic Coated headers Dual Cat type
ProComp Billet aluminum computer controlled distributor.
Taylor 8MM wires with Center bolt style separators
Crane adjustable Fuel pressure regulator
52 MM throttle body with integrated air foil and roller bearing throttle linkage.
52 MM port matched plenum
Custom ECU Prom with integrated diagnostics for recording car\ sensor data
Transmission:
Built 700R4, all new performance hard parts including "beast" sun shell, Servos, pump, boost valve, bands, bearings and clutch pack.
Old May 6, 2007 | 03:23 PM
Gramps's Avatar
Car: 87 Camaro IROC
Re: any thoughts on this set up?
i like the setup. when you gonna update your torque converter and rear end gears?
Old May 6, 2007 | 04:49 PM
avro206's Avatar
Car: 89 Formula
Well maybe when I buy the car
Whats wrong with the grears? 3.27X3.06 (first gear) thats prety steep
Don't think I will do a thing to the drivetrain though. I'll take it to the track and see what she runs. Be nice to have a 13 sec car---hopefully
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Mickeyruder
Sep 2, 2015 02:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
