Vaccum Leak
Old May 7, 2007 | 08:01 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
Vaccum Leak
I've got a vaccum leak somewhere near the distributor but can't locate it. Does anyone know what could possibly be leaking under the runners. I'd like to find out before taking things apart for no reason. The car was also throwing these codes:
12 - no reference pulse to ecm
22 - low voltage to the tps
33 - high voltage ( low vaccum) at mass air flow sensor
I figure the last code goes along with the vaccum leak im hearing near the back of the engine.
If anyone has any ideas or have had similar experiences let me know.
Old May 9, 2007 | 11:11 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
Re: Vaccum Leak
some tricks i picked up when looking for a vaccume leak while in my highschool autoshop ( teacher was a diehard morpar guy and knew his stuff)
get a propane tourch turn on the gas and start going in there area you think the leak is and follow the vaccume lines if the idle calms down or raise or lower youy found your leak
no gas use break cleaner or soap water and listen for the idle to change again
also did you check the vaccume advance on the distributor the plastic lines on mine were cracked and it took me forever to find it
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
