old gaskets
Old May 11, 2007 | 04:47 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
old gaskets
im replacing my runners, any tips on how to remove old gasket residue from manifold safely? without getting residue in the manifold? ive been using a putty knife but still having no luck. thanks
Old May 11, 2007 | 09:21 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: old gaskets
I use my angle grinder with a soft pad on it, and just whiz it all off....but if you dont have that, then try a razor blade, some gasket remover in the spray cans, or continue using the putty knife. Some real fine sandpaper won't hurt anything either.
Old May 12, 2007 | 09:09 AM
Vader's Avatar
Re: old gaskets
Scraping is safest. If you are concerned about bits and pieces in the runners, use a shop vacuum to clean up after yourself when you're finished scraping.
Old May 13, 2007 | 07:59 PM
Re: old gaskets
Yeah I should have mentioned it's also advised to spray the part down thoroughly with parts cleaner, or a blow gun.
Old May 13, 2007 | 09:24 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: old gaskets
i use a razor blade most of the time.
to help keep any of the old gasket & other debris from falling into the base, stuff a shop towel into each port of the base. blow off the scraped off old gasket material & then pull the shop towels out.
using a shop vac when you pull the towels out also helps keep anything from falling in too.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
