Cleaning Plenum...
Old May 14, 2007 | 02:56 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Cleaning Plenum...
I got my plenum ported and polished, but it's filthy inside...
Concerning cleaning it... I know that Eagle One Etching Mag Cleaner would probably clean i really good... should I use it? I've heard that the insides of some intakes have a coating that if removed / damaged could hurt it...
Raf
Old May 14, 2007 | 08:19 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: Cleaning Plenum...
If it were me I would try some Seafoam Deep Creep spray. It should be about $6 from Autozone or Pep Boys.
Old May 14, 2007 | 08:45 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Mine is dirty too, dark black soot i guess. Its hard to get off. I used a rag wrapped around a screwdriver with various sprays like brake cleaner, carb cleaner, etc. and scrubbed around. Its still dirty, but is that really bad?
what i would be more concerned about, is why is it dirty? is something unusual or is the soot crap normal for whatever reason?
Old May 14, 2007 | 10:38 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the sludge is completely normal. most of it comes from crankcase vapors being pulled in to the plenum. some comes from the EGR system. all port injected motors do it.
if you have access to a 5 gallon bucket of carb cleaner, the type that is used when doing a carb over haul, you can soak the intake in it & then wash it out with water. having it hot tanked also works. if you can't soak it or have it tanked, the car wash will remove most of the sludge.
you can cut down on the sludge build up by placing inline fuel filters in both the PCV hose & the breather hose. if you do this, expect to have to change the filters, a lot. they will get clogged up in about 2000~5000 miles depending on the condition of your motor.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
