does tpi need vss?
Old May 15, 2007 | 02:33 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
does tpi need vss?
i read somewhere that the tpi computer uses the vss sensor. is this true? also i am not sure if i have this sensor. i have a 91 with a 350 tbi in it with the 700r4 tranny. thanks -jon
Old May 15, 2007 | 11:33 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: does tpi need vss?
The vss is a required piece. If you don't have one installed it will trigger an engine light, among other things.
Old May 16, 2007 | 12:08 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the speed density TPI's use a 4000 pulse VSS unit. All 90+ Camaros use an electronic VSS (86+ on Firebirds). But I am not sure if the TBI's use a 2000 pulse or 4000 pulse, and then convert it to 2000 pulse.
Old May 16, 2007 | 02:29 AM
does a maf tpi system use it to?
Old May 16, 2007 | 11:21 PM
Kevin91Z's Avatar
All EFI cars use a VSS so the computer knows how fast the car is going. The 89 and earlier Camaros use a cable driven speedo, but the VSS is mounted behind the speedometer in the dash.
The 86 and up Firebirds use a VSS mounted in the transmission. The 85 and earlier Firebirds use a VSS in the speedometer with a cable drive, like the Camaros.
The 89 and earlier MAF cars use a 2000 pulse VSS.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
