really rich idle and stalling
Old May 17, 2007 | 02:16 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
well I just fixed one problem then I had another problem......... now I thought I had the car running great, and its messed up again......
Anyways, the car is a 88 GTA L98 143K miles all stock except 1.6 RR's
The car has been running good but now when I crank it and let it idle it will barly run and puff smoke pretty bad. If I tap the throttle it is fine or if im going down the road it is fine.
Also after I drive the car down the road it will idle fine, the check engine light is on but I cant get any codes out of it except 12
Also when I floor it going down the road once the rpm's get up to aroun 4000 it will blow oily smoke out under the dash, i can see the smoke coming out of the steering coulum it looks like.
HELP!
Old May 17, 2007 | 07:12 PM
wannafbody's Avatar
Car: 88 GTA
Re: really rich idle and stalling
hmm.......... now the car is fine??????
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
rjcme
Sep 5, 2015 01:23 PM
