Map sensor voltage???
Old May 18, 2007 | 05:16 PM
Raiden's Avatar
Man O man,
I've had the car problem from hades! I've no codes, but found something interesting. My map sensor is reading 4.76 @ idle, or Key on engine off. When I start my car, it runs as if it only has 4 cylinders! NO codes, right. Now, I have a 2 bar map sensor that belongs to my timing retard for my supercharger. I take it off my crane box and i put it on the stock harness and I get 2.33volts at idle or koeoff. My car actaully idles a bit better, not a whole lot, but it atleast runs. I get a code 33 after I use that map sensor.
What is the voltage supposed to be for idle and wot at the map sensor. I thought it was around 1.5 for idle and 5v for wot.
Thank you!!!
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
customblackbird
Oct 1, 2015 04:30 PM
327IROC85
Sep 23, 2015 12:11 AM
ULTM8Z
Sep 16, 2015 09:15 AM
