no start after CFI to TPI swap
Old May 20, 2007 | 01:47 PM
smoove2022's Avatar
I am getting spark and injector noid light is flashing while I crank. I am suspecting the fuel system as pressure only builds to 25psi max with tpi adjustable fpr turned all the way up. It builds to 25psi while pump is spinning and then drops to 20psi after. I swapped my fuel pump out a few years ago to a stock '85 corvette fuel pump (as I remember) but I'm still using the cfi fuel filter. Will the injectors fire if fuel pressure is to low? I am using an 85 computer and harness so vats is a non-issue.
Old May 20, 2007 | 02:20 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: no start after CFI to TPI swap
25psi is not correct for that tpi. you need like a solid 40 to run properly. the 85 computer is not the best for a tpi swap from what i have read. but i dont think that is your problem.
Old May 21, 2007 | 07:28 AM
smoove2022's Avatar
so would the low 20-24psi fuel pressure be preventing it from starting?
Old May 21, 2007 | 06:26 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
yes. i would go and buy another filter and pump. pump sounds like its a tbi or cfi pump. try an 85 z28 with a "f" engine code.
Old May 27, 2007 | 08:37 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I have the crossfire filter and a TPI fuel pump on my 82 vette and it starts up fine.
Old Jul 15, 2009 | 05:17 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
drathaar907
Aug 6, 2015 04:20 PM
