Painless VSS wiring adaptor?
Old May 23, 2007 | 07:53 AM
SS ninja's Avatar
Engine: 5.7 vortec crate w/TPI
Transmission: 2004r
Hi guys,
So I bought a VSS from Painless performance so I would be able to run my mechanical speedo while also supplying the correct signal to my ECM (4000 pulse).
I've got a slight problem though; the connector for the VSS is completely different than the connector on my harness...
Harness connection:
VSS:
Does anyone know if there is an adaptor for this, or do I have to splice the wires together? If I do have to splice them, which wires go where?
Old May 23, 2007 | 04:48 PM
S10Wildside's Avatar
Re: Painless VSS wiring adaptor?
I've always cut that connector off and installed a two cavity weatherpack connector. We have them at http://www.eficonnection.com/eficonn...atherpack.aspx. It shouldn't matter which black wire goes to the purple wire and which black wire goes to the yellow wire. You'll still get the VSS pulses you need. You can call Painless to confirm.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
GTAman
Aug 27, 2015 10:29 PM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
