Throttle cable question
Old Sep 12, 2000 | 01:20 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
I was just looking under the hood today and noticed my bottom throttle cable looked loose. I touched it with my finger and it had a lot of give to it....how tight should it be and can it be adjusted??
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood K&N filter air foil Stage 2 Fastchip B&M Stage 2 shift kit Flowtech shorty headers SLP 3'' exhaust Cams HI-6S igntion with PS-91 coil MacEwen white gauges overlay's SLP rear sway bar Koni's all around and one kick *** stereo!
Rice....it's whats for dinner
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
Old Sep 12, 2000 | 02:22 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
thats not a throttle cable, thats your TV cable (Throttle Valve)
thats what controls what rpm the transmission shifts at relative to how much throttle you are giving it. (i.e. when you are just cruising around the car shifts at 1500 rpm or less, but when you floor it it doesnt shift till 5000 rpm for instance)
The cable is adjustable, if you follow the cable back youll see where meets a bracket, on the sideof that bracket youll see a D shaped button. What you need to do is grab the slider, which is right where the cable goes into that bracket, and is on the cable, push the slider to the back of the car while pressing in the D shaped button. Youll see this increases the tension of the cable
now get in your car and with the car off push the accelerator pedal down to the floor. Youll hear some clicking from the engine bay. Thats the TV cable setting itself.
Old Sep 12, 2000 | 04:35 PM
Guest
Guest
Posts: n/a
Over time, I have seen those rip the teeth off the adjustment area, so after you adjust it make sure the cable has some tension in it (especially when open) and the adjustment part cant be pulled out by hand, otherwise its shot. If you dont ever get tension in the cable, its either broken or disconnected in the trans, which is something you definitely need to fix.
Old Sep 13, 2000 | 07:13 AM
fly89gta's Avatar
Car: 2018 Camaro SS
OH DUH!!!!! i freakin knew that.....damn.....i totally forgot about that.......nevermind
Old Feb 17, 2014 | 09:24 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Re: Throttle cable question
You seriously just bumped a 13+yr old thread? Are you a ****ing idiot?
EDIT: I see the mods took care of that, carry on, nothing more to see here.
Old Mar 9, 2014 | 02:21 PM
David Dempsey's Avatar
Car: 92 Firebird
Engine: 91 350 TPI
Why would that make you so angry, fly89? It's just a thread.
Old Mar 9, 2014 | 02:22 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Message board etiquette..plus he was advertising something that had nothing to do with my question from the last DECADE lol
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
