TPI Injectors
Old May 27, 2007 | 01:57 PM
Olav's Avatar
TPI Injectors
A friend of mine have these injectors for sale. Will they fit my TPI intake?
I know some ford fit Chevy TPI Intake
Ford Racing B-302 30# "Red Tops" 0280150756
Olav
__________________
-79 Camaro: SB355 TPI with Haltec,TRW, WP, PST, Wette brakes and products, Revolution, Aeromotive, SS lines
www.cardomain.com/ride/2233875
www.texasgutten.net
Old May 27, 2007 | 04:35 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: TPI Injectors
Find out what they flow ? I am thinking you want around a 22 lb injector ( unless you can change the injector constant in the prom) . Also remeber the ford injectors are rated differently . So factor that into the prom change. Like the 19 lb injecotrs for a ford ....maybe closer to a 21 lb ...by GM's rateing
Old May 28, 2007 | 01:41 AM
Olav's Avatar
Re: TPI Injectors
Flow is 30lbs thats about I want. I have Haltec computer. I'm not sure if they fit my intake and fuel rail....... ( tpi injectors are 19lbs on the 305 and 22 on the 350's)
Old May 28, 2007 | 10:41 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Re: TPI Injectors
I know my friend, I put edelbrock headers on, and a fresh cat, with ford SVO injectors, failed emissions, and couldn't get the car to pass at all, and they were 19 lb/hr ones too. You may want to keep that in mind. If you don't add a cam, more cubes, or use a HSR intake and are making 550 hp, then the stock 22 lb/hr will support you to 450 horses, according to TPIS. Those guys know there ****.
Steve78LT
Feb 24, 2016 12:15 AM
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
