Rookie in need of help!!!!
Old Sep 18, 2000 | 07:03 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
alright heres the thing,I have a 89 350 IROCZ it has a prob, at a cold start, It will catch but then die. I checked it with my scanner and it showed that my MAP sensor isn't responding quick enough, But like the title states Im a rookie. Vader said there s no MAP sensor only a MAF, I don't think I set up the scanner wrong, but also when I did the trouble codes two came up, 22 and 33 oh 33 said MAF\MAP sensor was too high. I already changed the EGR valve and it hasn't help, my mpg is really bad right now. Does any one have an idea what is wrong? oh by the way the SES light hasn't came on and if it helps my car stalls every once in awhile. Someone said it might be my fuel pump regulator, might be causing it. does anyone have any sugguestion?
Old Sep 18, 2000 | 07:59 PM
Mike89GTA's Avatar
Vader is right, it does have a MAF sensor, 90 was the first year of MAP. I don't know much else though, sorry.
4 bolt 350, 10.4:1 Compression, Edelbrock Aluminum Heads 6085, LT4 Hot Cam /w 1.6 full rollers (Crane), Scat Crank, SLP 1 3/4" Headers, SLP Cold Air Intake, Crane AFPR, 48mm TB, ported plenum, stock runners, Accel Super Ram intake manifold, 95Z #24 injectors, stock fuel rails, T5 Tranny, 3.45s, 9 bolt rear, 4 wheel discs, BFG Comp T/As rear, SZ50s in front, Alston SFCs, ES Trans Mount, ES front A-arm bushings, ES front sway bar end links
Old Sep 18, 2000 | 08:10 PM
rondubbs's Avatar
with the codes you are getting it seems to be related to your tps sensor (throttle position switch). either it died on you ,, which would be the cause of your stalling , or it needs to be adjusted.. make sure the voltage at the tps is at .54v DC. and when you move the sensor up an down the volts also go up and down.. it is located on the left side of the tb when you are looking at it. if that turns out to be fine then its the maf sensor,, its dead!!
good luck
[This message has been edited by ron rizzotti (edited September 18, 2000).]
Old Sep 18, 2000 | 09:30 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
hey thanks alot ron,
yeah I ll check it out tomorrow, well actually my buddy set it up along time ago to get alittle hp, it s been fine ever sense then that was years ago, well it probably just went bad though, well thanks I ll let you know how it goes
TheExaminer
Sep 6, 2015 11:40 PM
BADDEST305
Jun 28, 2004 05:45 PM
fakeyankee
Apr 7, 2003 03:43 PM
SgtSkip
Sep 8, 2002 08:41 PM
know_bull88
Jul 24, 2000 10:36 PM
