LB9 EGR help
Old May 29, 2007 | 10:27 PM
ToplesIROCmedic's Avatar
Car: '89 IROC conv.
Engine: 5.0L F
Transmission: T-6 world class
Axle/Gears: yes
LB9 EGR help
89 5.0 LB9 TPI motor. on the EGR solenoid that sits under the coil bracket-what plugs into the back of the solenoid next to the electronic plug? It looks like maybe a vacuum plug. I know that the EGR valve and throttle body plug into the front of the solenoid, but can't find a loose hose or wire. HELP!!! Please!!! going for smog tomorrow. THANX
Old May 29, 2007 | 11:26 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: LB9 EGR help
Sounds like you have it covered. The hose to the EGR under the plenum. The hose that goes under the throttle body. Then the electrical plug.
Old May 30, 2007 | 12:05 AM
Car: '89 IROC conv.
Engine: 5.0L F
Axle/Gears: yes
Re: LB9 EGR help
yes, but there is a third vacuum connect port on the back of the solenoid. what goes there??????
Old May 30, 2007 | 06:59 AM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: LB9 EGR help
nothing goes there, there should have been a cube shaped foam filter over it held in by the little prongs on both sides.
Old May 30, 2007 | 12:07 PM
Car: 1989 GTA
Engine: 369 TPI
Re: LB9 EGR help
Exactly. It is just a vent to the atmosphere.
Old May 31, 2007 | 12:28 AM
Car: '89 IROC conv.
Engine: 5.0L F
Axle/Gears: yes
Re: LB9 EGR help
thanks a ton, guys. that explains why, after spending a half hour looking under and behind the block, I couldn't find anything.... Awww, Chevy, How I love thee!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
