ecm ?'s
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
ecm ?'s
im gonna be converting to tpi here soon. the ecm i have, is for a 305 tpi auto. my question is should i get an ecm thats for a 305 tpi manual since i have the t-5. does it matter which one i use? would i be fine just running the auto ecm?
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: ecm ?'s
I am certain it does matter, can't recall all the reasons, but only in the PROM. You just need a manual trans prom for the ecm.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: ecm ?'s
As PneumaticTire said, the ECM's are the same, its the prom inside that is different. With a stockish engine, it probably wont matter, but there are subtle differences that might make it tougher to run a manual with an automatic prom. The Idle Air motor is one. The car will probably want to stall when you push in the clutch while slowing down.
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: ecm ?'s
what year is youre auto prom? if you are going to buy the manual one, maybe ill buy the auto one.
Car: 1988 firebird
Engine: 305 tpi
Re: ecm ?'s
thanks for info guys. 8T9 bandit my prom is from an 87. ill prolly just run with it as is for a lil while. and then switch to the manual prom once i really starting modifing the tpi.
efiguy
Sep 27, 2015 01:30 PM
