tbi to tpi
Old Sep 11, 2000 | 02:05 AM
ausrs's Avatar
tbi to tpi
from memory there used to be a tbi to tpi tech article ..does it still excist ???
i bought a 1986 tpi and want to install it on my 1991 ..just need some info from it
thanks if anyone can help
steve
Old Sep 11, 2000 | 03:38 AM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
Look in our <a href="https://www.thirdgen.org/newdesign/tech">Tech Section</a>.
I believe Mauro's TBI to TPI article is in there. Yep, it is, I just checked
Old Sep 11, 2000 | 05:39 AM
ausrs's Avatar
thanks dirk ..i missed it
btw great to see you back online
Old Sep 11, 2000 | 06:58 AM
ausrs's Avatar
i found the article however it is tbi to map tpi ...can maf tpi work on 1991 and keep all other accessories working ...ie speedo ???
Old Sep 11, 2000 | 08:20 AM
Bill91Z
Guest
Posts: n/a
What exactly did you buy? Did you purchase a harness already, ECM, PROM??
If you just bought the intake set up, might want to think about going with speed density anyway. It would be easy to convert if you didn't already buy the harness and computer related stuff.
Let me know and we'll go from there
-Bill
1991 Z28, 305TPI, 5-speed,
AS&M ported & polished intake, AS&M polished LTRs, AS&M port matched plenum, TPIS 52mm TB, Richmond 3.73s, SSM SFCs, SLP LCAs, SLP panhard, ATR 3" exhaust, MSD 6al, Taylor 10mm wires, SLP PROM, and a host of other stuff.
Old Sep 11, 2000 | 10:56 PM
ausrs's Avatar
the tpi i bought was from a 1986 corvette
consists of
harness
ecm / prom
runners
manifold
all associated sensors that where attached to the motor a brand new maf sensor
the auto kickdown cable
+ other stuff that i dont need (serpentine belt setup ,alternater etcetcetc
it was everything that was bolted to the motor because the motor was ending up in a hotrod with carb
Old Sep 12, 2000 | 05:24 AM
JP84ZROC
Guest
Posts: n/a
I just completed a similar swap and I am very pleased with how it turned out, will be glad to offer any help/suggestions you may need.
"84Z28/'91 305TPI comp cam flowmaster TB coolant bypass/shutoff valve to heater core MAT relocated Ram-Air(home-made) gutted air-box IROC ground effects/wheels GY245/50's 700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Old Sep 15, 2000 | 04:51 PM
Mauro's Avatar
Hey AUSRS,
I got your email. I am half way through writing it, it's long
You should get it by this sun.
WWW.SC3GFB.ORG
FOR SALE
1990 RS/TPI/DFI 355 T-5
13.20 @ 106 with no tuning.
Edelbrock: Performer RPM Heads, Water Pump, TPI base, TES Hedders and Cat-back.
LT-4 Hot Cam
NO, AC, spare, jack or rear seat.
1LE Driveshaft, GTRotors in front and PBR Calipers in the back.
Koni front and rear swaybars, KYB shocks.
Old Sep 15, 2000 | 04:52 PM
Mauro's Avatar
Double post
[This message has been edited by Mauro (edited September 16, 2000).]
Old Sep 16, 2000 | 12:07 AM
ausrs's Avatar
thanks mate
bad news at the moment ..bloody freight company has "lost"
my tpi sure hope it turns up soon !
Old Sep 21, 2000 | 08:19 PM
ausrs's Avatar
hey tpi turned up .......no explanations it just arrived!
without getting into debate what is the easiest conversion for my car maf or map ??
remember i want to keep the speedo working here
cheers
steve
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
