Speedo gears for 700R4 and 3.73's
Old Sep 20, 2000 | 08:19 PM
markz28's Avatar
I am going from 2.73's to 3.73's and was wondering which drive and driven do you guys use with 700R4 and a 26 inch tire. In the tech section it says a 15 and 45 tooth set has anybody used these and how did they work?
Old Sep 21, 2000 | 03:26 PM
markz28's Avatar
Nobody has any experience with the 2 gears and sleeve? The parts guy at the chev. dealer said that maybe I could get by with a "adapter" that fits btw. the 2 gears, he said there is a 73% adapter available. He said guys with pickups use them after gear swaps but also said there is alot of clearance there also.
Old Sep 22, 2000 | 12:12 PM
Hank Brote's Avatar
You have the right combination of gears and the swap isn't that hard. In fact a friend of mine did the write up on this in the tech section. I haven't done mine yet.... I've got to get down to GM and get the gears.
Hank
87'IROC Z28
Hanks 87 IROC
Old Aug 20, 2014 | 09:48 AM
jahblah's Avatar
Car: 87' Firebird Formula
Re: Speedo gears for 700R4 and 3.73's
Sorry to bring up an old thread but rather continue with the same subject than start a new thread about the same thing. My front tires are 245/50r16 which is a 25.65 and rear tires are 235/55r16 which is a 26.18 (googled myself a tire size chart).
#1. Is it safe to consider both front and rear 26" tires for my speedo gears?
#2. And are these the correct speedo gears for the 700r4 trans? I ask because the driven gear says "GM turbo-hydromatics" which i was thinking that it was referring to the TH350 or TH400.
Drive: http://www.summitracing.com/parts/tci-880018/overview/
Driven: http://www.summitracing.com/parts/tci-880032/overview/
Old Aug 20, 2014 | 10:12 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Front tire size doesn't matter. The rear tires, rear end gears, and speedo gears are all that matter. Scroll down to the speedo gear section for a speedometer gear calculator in this link. http://www.transmissioncenter.net/sp...n_______va.htm
Old Aug 20, 2014 | 10:19 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
26.18 is probably close enough not to matter. Turbo Hydramatic refers to more transmissions than the 350 and 400. They're just the most famous.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
andy74
Sep 3, 2015 08:41 AM
