Can I use my JET stage 2 chip with Nitrous?
Old Sep 21, 2000 | 03:05 PM
Brandog87GTA's Avatar
??? I just bought the chip a week ago. Should I send it back and get a refund?
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with Bosch platinum plugs, Accel distributor cap and rotary buttons.Gutted cat. Hope to port runners and plenum in about 2 weeks.
Old Sep 22, 2000 | 12:33 AM
NICK 86 TPI's Avatar
did you feel a difference w/ the chip?
what kind off 1/4 ml. improvement, if you raced it?
sorry i don't if you should send it back but you should not have to, the N2O doesnt have anything to do with the ECM, i dont think
Old Sep 22, 2000 | 08:01 AM
Well actually, the chip speeds up the timing so it would have an effect on my system if I am running NOS. Off the line the chip did not effect my car much, but on the highway you really feel the difference. I guess it is because it adds more horses than torque. It flies on the highway now. I think the chip is worth it, the only problem is that you have to use ur old prom. I wish it was a whole new prom.
Old Sep 23, 2000 | 12:01 PM
JeffP's Avatar
Yeah, the instructions you get in the kit will tell you to use the stock prom with the nitrous setup. Take it out!
1989 IROC-Z
305TPI/A4
ROH Wheels, Eibach springs, & alot of wasted money
Old Sep 24, 2000 | 11:33 PM
Jegs and summit both said I could use the chip with it. I honestly dont know who to believe.
Old Sep 25, 2000 | 01:45 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Well think of it this way. With nitrous you are suppost to retard timing, the chip advances it, take it out. I also have a chip and nitrous, and I take it out when I spray it. But then again its your engine.
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
