P/N for an A/C accumulator thermal blanket from 2000 TAHOE that work on ALL F-BODIES
Old Sep 25, 2000 | 01:05 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey guys, I know you all know how much HEAT our engines produce, and that heat is transfered to our A/C accumulator and most probably reducing the A/C system's efficeincy. I just looked at a 2000 TAHOE and GM has already solved this problem with a made to fit accumulator THERMAL BLANKET. I have a buddy in VA. look up the P/N and price and it is surprisingly cheap.
GM P/N-- 15022186 for $5.75 each
I just thought that this will help a lot of us that still have A/C. Later and drive COOL and FAST.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
[This message has been edited by 88SS6SPEED (edited September 25, 2000).]
Old Sep 25, 2000 | 06:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
That would be great, but consider that the refrigerant has already passed through the evaporator once it hits the accumulator, so it shouldn't make a difference, but I guess every bit helps.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
