Accel Runners
Old Sep 20, 2000 | 05:19 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Accel Runners
I just picked up a set of Accel runners for $100 still in the box and never mounted. My list of mods is below, but my question is, should I just bolt these on, or port the base while i'm changing the runners, or just put them asside until I get a new motor with heads and cam that will compliment them? any experience in this department will help a lot.
89 Trans am GTA, Magnaflow cat-back, K&N conical air filter, air foil, cooler fan switch and thermostat
Old Sep 20, 2000 | 06:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Definitely port the base while you've got the upper intake apart. It'll make a huge difference. The runner-to-manifold ports on the stock intake are tiny!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Well, I don't think that you'll gain a whole lot by bolting them on right now, but it's only like 8 bolts per side to pull the runners off - so I'd say slap 'em on.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Sep 20, 2000 | 07:22 PM
rondubbs's Avatar
i would port the plenum too, http://www.tribal-treasures.com/cars...-port/port.htm
Old Sep 21, 2000 | 09:21 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
If you need help with the porting, let me know. I'm porting plenums for $60, gasket matching the runners for $40, and fully porting the GM intake for $275. See http://www.isthq.com/~dan/efi.html for details.
Gotta defray the cost of my car addiction!! Minirammed 383 in the works!
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Old Sep 23, 2000 | 11:32 AM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I would suggest at least gasket matching the plenum and lower intake to match the larger openings of the new runners. It might be tempting to just slap 'em on, but since the runner openings are larger than the stock base openings, the air flow transitioning between the runners and the base would encounter a significant ledge where it tried to enter the base. At the very minimum, that opening in the base where the runner mounts needs to be enlarged enough so that the air flow can smoothly enter the base without turbulently tripping over the diameter transition.
Old Sep 27, 2000 | 01:22 AM
Tom Keliher's Avatar
Doing nothing other than installing the Accel runners, netted a 3/10's reduction in 1/4 mile ET at a 2900' altitude dragstrip on my essentially stock '89 Formula 350.
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Sep 27, 2000 | 06:58 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Like others have said I would go ahead and use them. I dont have any before and after test results. But my car did pickup some good power. I ported the plenum at the same time though.
One thing I like about the Accel runners is they are cast not tube style. With tubes you cant really open them up much. The cast runners can be ported out for more flow. With porting they will out flow any non siamesed long tube runner.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
