305 TPI unit on a 350
Old Sep 27, 2000 | 08:17 PM
rwendt's Avatar
Car: 1991 Camaro Z-28
Transmission: 5 Speed Manual
This has probably been asked, but can I use my 305 TPI unit on a 350 that I am building? Do I need differant injectors? What else do I need to change? The 350 is going into my 91 Z28 and I will be using the stock 5 speed.
  • 1991 Z28
  • Ultra Metallic Blue
  • 305 TPI
  • 5 Spd Manual
  • 3:08 rear axle
members.fbody.com/rwendt/
Old Sep 27, 2000 | 08:46 PM
MrJ's Avatar
MrJ
The TPI unit is the exact same for both engine. The 305 injectors are 19lb/hr, and the 350 units are 22lb/hr. You'll want new injectors eventually, but for now, you could run the 305 injectors at a higher than stock fuel pressure and do fine.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
Old Sep 27, 2000 | 09:30 PM
Stell1579's Avatar
Nod, the Injectors and i believe the prom chip is diffrent aswell as the knock sensor
-Stell
Jake_92RS
Jan 28, 2020 10:37 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
