Wrong throttle body
Old Sep 27, 2000 | 12:47 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Wrong throttle body
I accidentally bought a throttle body for the '85'-'88 TPI units. My car is a '91 w/TPI. Can I make it fit my car by just changing the brackets or something like that? Any help is appreciated.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Old Sep 27, 2000 | 07:16 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I think you would need a 85-88 throttle cable for it too work. You also might need to drill a hole for the idle air in the front of the plenum. Its a little easyer going from an 85-88 to a 89-92 TB.
I was going to do the same thing i didnt want to mismatch parts so i bought a new one.
Good luck, here is some info on them Scroll down to were it talks about the castings: http://www.fuelinjection.com/portinj.html
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited September 27, 2000).]
Old Sep 27, 2000 | 10:31 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Mike is right I would return it and get a new one. It will be expensive and a pain to get it to fit.
Old Sep 27, 2000 | 09:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It won't work without some major modding (and not sure even then) the IAC passages are different from the TB to the plenum on the different TB's,...might be possible to mod the plenum though, I don't recall which one has a hole in it, and which one doesn't.
At any rate, get the proper one.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
