I know I screwed somthing up but dont know what?
Old Jun 3, 2007 | 10:50 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I went to start my car and noticed no prime at fuel pump. Tested pump and it runs but doesnt reflect any pressure build on gauge? Disconnected fuel line at rail and ran it....fuel came out. so pump is working.
Relay is not cycling.
One possibility of my mistake I might have disconnected and reconnected my battery while key was in ignition position. I was doing a lot of wiring and testing and might have forgot to return it to off posn...I am not positive I did this.
I have painless TPI harness and tested fuel relay at red lead and it worked I checked voltage to ecm at fuses in painless harness and read 12 volts.
could I have tweaked my ECM if so would the symptoms be as I described?
why the no pressure at gage though when I power pump with jumper....the gage is not electrical.
I never drive the car and just start it occassionally and I did have power to the fuel pump last week before I installed my keyless entry. that is when I might have connected and disconnected bat with key in on posn.
let me know your thoughts
thx
jeff
Old Jun 3, 2007 | 11:25 AM
bfox88's Avatar
Car: 90 IROC-Z
Re: I know I screwed somthing up but dont know what?
check the fuse?
Old Jun 3, 2007 | 01:12 PM
jjlabinski's Avatar
Engine: shinny 350
already did wasnt the culprit
Old Jun 3, 2007 | 01:17 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
try a new relay. If power is there, the relay should energize. If it isn't, the the problem is with the relay.
Old Jun 3, 2007 | 02:59 PM
jjlabinski's Avatar
Engine: shinny 350
relay works fine I tested it at the red jumper. power isnt there and am trying to figure why not. I went and bought a new ECM .... that was not the issue. I am still stumped
Old Jul 25, 2007 | 04:05 AM
thedoctorisin's Avatar
Car: 79' LT1 olds cutlass/ 87' IROC
ive got an 89 350 tpi suffering similar troubles, not olny does my fuel pump not work but my injectors dont pulse either. there is a large orange wire that should always have 12volts to it even when the key is off. i believe that the ecm also uses this power source for its memory.
Old Jul 25, 2007 | 06:34 PM
jjlabinski's Avatar
Engine: shinny 350
I figuered out what my deal was a few weeks back. The battery was bad.
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
Bigold4x4
Sep 28, 2015 05:21 PM
