What all tools do I need in order to take a complete TPI off of a 89 formula??
Old Sep 27, 2000 | 06:41 PM
brent walden's Avatar
I need to take everything off that I would need inorder for it to work on my ZZ4 that I am going to get. Also where is the wiring harness for the TPI located??
Any help greatly appreciated!
Thanks!
Brent
Old Sep 27, 2000 | 06:47 PM
Doug E's Avatar
Dude,
You can't put a TPI on the ZZ4. The Vortec Heads don't accept the TPI manifold.
Anyway. Get a set of torx wrenches. There are only two sizes of torx bolts on the whole setup. It comes apart real easy. The triangle thing that the throttle cable and TV cable ride on is a 10 mm socket. The fuel lines are a standard size wrench, but I can't recall what size.
!!!! Discharge the fuel pressure at the schrader valve on the fuel rail before you unhook the fuel lines!!!!
To remove: Take off all bolts holding it on
Old Sep 27, 2000 | 07:19 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Actually your TPI will bolt up to a ZZ4. The ZZ4 has the aluminum L98 heads (like the Corvette) so the bolt pattern is the same. And as for the wire harness; you'll have to remove all of the sensors from the old motor and put them on the ZZ4 and attach the wire harness the same way.
1991 Z28 - 350 TPI, T56, Centerforce Dual Friction clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old Sep 27, 2000 | 10:21 PM
Where are all of these sensors located and how many of them are there?? How long should I expect it to take me to take the tpi and allof the sensors off??
Thanks!
Brent
Old Sep 27, 2000 | 11:35 PM
Doug E's Avatar
Getting the plenum, runners, fuel rail and manifold off shouldn't take long at all. Like between a half hour and an hour.
As for your wiring harness, good luck. I really pity you if you try to do it on a car with an engine still installed.
I've only removed these things to swap engines into cars with TPI, not put TPI on otherwise equipped engines. Sorry
Old Sep 28, 2000 | 12:51 PM
Blade's Avatar
Just for the TPI you'll need a Torx T40 and a T50 (I think) for the intake bolts. Other than that, a strong flat blade screwdriver, a crow's foot distributor wrench, 10MM socket and open end wrench, and a T30 to remove the valve covers (makes it MUCH easier to get to the bottom bolts underneath the runners). Fuel line wrenches ( I do it with two crescent wrenches, lol).That's all I can think of...
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
Sanjay
Aug 12, 2015 03:41 PM
