TPI Air intake
Old Sep 29, 2000 | 03:14 AM
Ehelmsin's Avatar
TPI Air intake
Just under the filters on a stock camaro air intake are easily removable "walls" that cause the incomming air to make two complete u-turns. I have done some research and found that these are to prevent water from getting into the engine. What is the possiblity of that? I have K&Ns, and I was told the oil on those will stop the water, is that true? I am just thinking that if I pull those it will give the incomming air a much smother path. Any thoughts would be appreciated.
~89 350 TPI Iroc-Z
Old Sep 29, 2000 | 07:53 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
The best thing to do is to cut the whole bottom box off! Thats what "gutting" of the airboxes means.
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Old Sep 29, 2000 | 09:01 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I didn't "gut" out my boxes, but I did remove those baffles - even before I had K&N's.
Old Sep 29, 2000 | 11:37 AM
Ehelmsin's Avatar
But will that do me any good? Did it work for you?
Old Sep 29, 2000 | 03:11 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I agree with Randy92Z...I would cut out the whole bottum just leave the lip for the filter to seal on. Ive driven my car in the rain may times and checked to see if there was any water. I did notice on the highway the car felt a little more responsive.
If you run a ram air type setup from the Fog lights then you might have a problem with water in the rain.
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited September 29, 2000).]
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
