Best Fuel Pressure
Old Sep 28, 2000 | 06:54 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Best Fuel Pressure
I got a 89 350 Formula MSD 6AL ,Supercoil ,TES Hi flow cat edelbrock cat back ,pulleys ,open element ,ported plenum ,crane AFPR. Thanks This will be for racing sunday.
Old Sep 28, 2000 | 07:29 PM
MIKES 88GTA's Avatar
TPIS insider hint books say 50psi but every one seems to get different result with different cars, just gotta try it out. I'd start with 50psi and work back down and then back up if you have to, since we all don't have a dyno in our garage SOTP is the only thing we have to go by.
Old Sep 28, 2000 | 11:17 PM
NICK 86 TPI's Avatar
44 to 48 psi would be best
without a custom chip to know your runnig 50 psi, it would not help any, with a chip 46 psi is good for daily driving and 50 psi for the track
Old Sep 29, 2000 | 04:38 AM
RP1987GTA's Avatar
I'm using a ADSchip,37psi at idle with vacum hose connected 47psi with hose disconnected works purdy good
87GTA,MAF screens removed,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster,TPS.54,Bosch Plat plugs,base timing 6BTDC,Bilstiens in the rear....,don't let yer meat loaf
Old Sep 29, 2000 | 08:20 AM
Bill91Z
Guest
Posts: n/a
Different with every car. You need to test and tune at a dyno or at the very least a track to get optimal results
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Sep 29, 2000 | 06:08 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I too say..."every car is different". Your existing mods and condition of your engine are great factors. I may have an imbalance in my fuel injectors which require more fuel pressure than yours or vice versa.
O2 readings are a good indicator if you have a scan tool. And even then, they can vary a bit from car to car. But generally, 02 readings of 900 mV is what seems to work the best @ WOT for most people. The flatness of the O2 readings is another indicator worth noting.
But the stat that is the most important is what you do at the track, given temperature, elevation and humidity. You can find that the optimum pressure for the best et will be different for a given day, if you are trying to bet the "best" times.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
