you think 373 gears are to much for 350 tpi
Old Sep 22, 2000 | 11:39 PM
bad camaro RS's Avatar
i went from 327 to 373 gears i have a few questions
1.you think ill see any gain in 1/4?
2.have any of you got your speedo to read right? whats the easiest way to get it to read right?
3.what do you guys shift at?
4.what do u suggest i shift at with my mods?
5.you think ill be"out of breath"by the end of the 1/4 with the 373 gears?
thanks in advace
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
Old Sep 23, 2000 | 08:54 PM
Kevin G's Avatar
[This message has been edited by Kevin G (edited September 23, 2000).]
Old Sep 29, 2000 | 06:27 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I too have a 3.73 rear axle to drop into my GTA, but I have no time to install them right now.
But, you NEED to change the speedo gears in your tranny. You don't state what your existing tranny is nor the tires you are using, so I can't tell you what combo you need. The combo for 3.73s with with 245/16/50s is a Grey 15 tooth Drive Gear (on the output shaft) and a Dark Grey 44 tooth Driven Gear.
The Driven Gear is a snap to change, the Drive gear is more work as you must drop the drive shaft and remove the tail cover to get at the gear on the output shaft of the tranny.
Hope this helps.
1nastygta
Oct 28, 2015 08:51 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
