Is it common for the cold start injector to be the "leaky" injector?
Old Sep 30, 2000 | 12:19 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Just trying to prove my leaky injector therory. I got all the injectors out, and paper towels under them to check for wet spots.
THERE ISN'T ANY! Well, I should say that the only wet spots I have seen is from the cold start injector. Other than that, perhaps a very small amount on an injector if I hold a paper towel up tight.
Is the cold start injector a known culprit?
Anyone?
I'd hate to replace it and bolt it back together only to find it was not it. But it must be if the others are dry. CAn you tell frustration is setting in?
Sniffin gas,
Mark.
Old Sep 30, 2000 | 02:13 PM
rondubbs's Avatar
well.. just to let you know,,, cold start valves are discontinued. i know because i replaced mine becasue i thought it was leaking and the friendly people at gm told they are no longer made.. i got one off ebay.. if you do need one email this guy tw448@aol.com... he has them.
goood luck
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
